Water in Gear Case.
johnm
After troubleshooting a particular problem for about a month, I have uncovered another. I have water leaking into my gear case.<br /><br />It's a 1979 55HP envinrude. I have read the chapter on gearcases in my manual but I would also like to ask where the most common place water would be entering my gear case. I believe there are 2 seals behind the prop and 1 that sits next to the water pump. Anywhere I should be looking?<br /><br />PS. For those that helped me out with the stalling problem, I'll let you know by end of week. I'm taking her out for the day.
D
DJ
Guest
Re: Water in Gear Case.
JohnM,<br /><br />By far, the most common places, in order, for water intrusion are:<br /><br />1. The fill/drain screws. Few people replace the o'rings/gaskets when they service the L/U.<br /><br />2. Prop shaft seals. Damaged by fishing line, etc.<br /><br />3. Water pump/drive shaft seal.
S.T. Marine
The places it could be leaking..... There are a few spots... The propshaft seals might be worn. The driveshaft seals under waterpump or drain screws. Drain the lower unit and pressure test it if you have access to a tester that will tell you where it is comming from
dpminc
As to the list above, I would add 1.5 shift shaft seal. This has one of those o-ring type seals, and they do leak often.
