1995 Cobalt 220 with 1995 Volvo Penta 5.8 FL DP-D w/ freshwater cooling
Over the July 4th weekend noticed rusty water coming out bilge when the transom drain plug was removed after a short boat ride. F.W flushed engine when I got home and found water coming out starter motor. Shut down engine and removed plastic Perko FW flusher - suspecting it had sprung a leak. Attached garden hose directly to onboard RW pump inlet hose and restarted engine. Water came runnign out of starter brush rigging end plate and bendix yoke solenoid housing. Removed the starter motor and found the flywheel bell housing half full of rusty water.
What would be the typical cause for the water leak into the flywheel housing of my DP-D Volvo sterndrive. I'm gussing that the drive shaft bellows has developed a leak and the resulting salt water has chewed up the inboard
drive shaft seal and most like messed up the universal bearings.
What would be the proper way to fix this problem. Does the engine need to be removed to get at the inner drive shaft seals - as well as the upper out drive housing to pull the drive shaft & bellows boot? Should the engine be removed as good practice for flwheel coupling inspection?
