Hey guys, here's one for you:<br /><br />I've been working on my older (1984) 7.5 hp four cycle honda since I burned out the impeller and got the engine a bit warm (or hot...)<br /><br />The engine started after my heating event, and I gambled to replace the impeller and shaft seal into the lower unit. Now when I run the engine, and it seems to run just fine, I quickly get water in the engine oil. The compression seems OK, but clear water is leaking out of the oil filler plastic fitting. I tried to tighten up the mounting bolts, but I still get water in the oil. Any good ideas? Thanks from Opa.
