Drowned Rat
- Jan 20, 2004
- 3,070
Just took out my 6hp 1974 Chrysler (Ward) and when I got back, I noticed water in the L/U. The drain/fill screw gaskets were in bad shape so I replaced them. The question is, how likely is it that this is where the water was coming from? The water pump seal looks ok. I don't notice any oil leaking around the prop, but then I didn't see any leaking from the drain plug either. If the prop shaft seal were bad, would I see oil leaking here? Thank you for any opinions on this problem.
