I recently bought a used 1989 Peterborough bowrider with a 3.0 litre Alpha One Mercruiser.<br />I used it quite extensively the first weekend I had it without a problem and left it tied to my dock at my cottage for the week. <br />When I got back to my cottage I noticed that some water had seeped through my boat cover into the back of the boat. I also noticed that some water had collected in the bilge area. I wasn't sure if the water in the bilge area was due to the rain or had come in somehow else.<br />Regardless, I bilged out all the water and tried starting the motor. I was unable to.<br />Closer inspection led me to check the engine. I saw that water had got into the engine. There was water in the carb, water came out of the (crankcase) oil drain when I drained it as well.<br />I immediately thought I was in a heap of trouble but hoping for the best I drained the oil and changed the oil filter. I then started the motor and took it for a couple of runs. All seemed fine, boat ran fine and the oil color seemed almost normal when checking the dipstick. I decided I should change the oil and filter again and did so. I then took it for another run and, if anything, the boat is running better then before this whole thing started.<br />What do you think?<br />Do I have two issues?<br />1- water coming into bilge area while boat is docked.<br />2- water getting into engine somehow<br />Or is it possible that water got into the engine because there was so much water in the bilge area?<br />My manual says that water can come into the engine through the exhaust if care isn't taken when launching the boat. From that I would assume that water could come in through the exhaust while docked from waves etc.<br />If it's not obvious by now, I am anything but a boat expert and I would appreciate any guidance.<br />I had feared that I had a major problem when I first saw that water had gotten into the engine but all indications are that I may be ok after the two oil and filter changes. The boat's running fine and the oil is clear. Please help.<br /><br />Sorry for the long message.<br /><br />Thanks,<br />Bruce
