anthonyburris
- Sep 20, 2005
- 8
i recently cleaned a lot of corrosion out of the head and replaced the head gaskets, and put a new impeller in a 8 hp nissan, 2 strk. now when i run it water only cones from the exhaust, it is a steady stream, but almost nothing comes from the tell tale. why is this happening? also the water is a little warmer than should be, is this because the engine is hot or becuase it is micing with the exhaust and getting hot? thanks alot!
