Re: water flow on 35 hp evinrude
ok so i looked at the holes a little closer and i can see the driveshaft throughout them. i'm kinda wondering now because i would think water would get in there just from running the boat because of how low they are. now whether or not it should be pumping out of there i'm still not sure. there is a spacer with o-rings that goes on top of the water pump that the driveshaft runs through. i'm thinking maybe if the o-rings were leaking then that might be it, i'm not sure any help would be greatly appreciated.
