Re: Water flow diagram
So here is the diagram off my manual. The way it is drawn, once again, is showing the water coming up to the backside of the thermostat(spring side) then flowing to the "pointed" side. If this were the case, then the picture right below shows that the thermostat is pointed inward, with the spring side pointed away from the block.
Am I just being really ignorant and just not catching something? I have not done it jet, but I will sit down with the actual parts in hand with the motor and try to visualize it. It is a matter of curiosity more than anything, except for the fact that the threaded plug that is used to add a tell tale is on the back side of the thermostat (pointed side) which by indication of the diagram means that a flow should not be seen in full force until it is opened.
But that goes against everything that I have been reading, unless that weep hole you spoke about, frank, lets enough water by to be seen coming out of the tell tale. Oh well, that is really the least of my problems, but I thought I would try to figure it out anyways.
