I have a 1983 mercruiser 5.7 gm with a pre-alpha drive serial 6817160. I was investigating an oil slick in the bildge. I started the engine and noticed water leaking into the bilge from a small machined hole just above the water inlet neck. It is on the transom assembly straight up above the engine shaft. It is not pouring in, more like an intermittant sputtering, like an auto waterpump leaking through a weephole.
I had the bellows & water pump replaced, & drive serviced 2 years ago professionally.
This may be unrelated, but I noticed that the oil pressure is a bit high ( 40psi at idle/ 60 psi at speed ) and the exhaust tone changes occasionally, regardless of trim position.
Any ideas?
Any ideas?
