Hi,
A few days ago I raised a problem I have with my old 6hp Evinrude. No cooling water from the normal exits when running the engine, just an initial stream (less than 10 secs), then a few splashes and vapour, then steam. I have tested the pump (new impellor) by driving the drive shaft with an electric drill and the pump ejects water from the top of the drive leg - the pump appears to work fine. This overhauled 6hp engine starts and runs well, has a new thermostat, and I have checked the water cooling passages and these are clear. New gaskets are fitted. After running the engine until the steam emerges from the water outlets (both the tell-tale and the exit on the drive leg) the thermostat is wide open, but apparently no water is reaching the top of the cylinder block. I have no idea what else to investigate as the pump seems perfectly capable of this duty - am I doing something wrong? Do the long shaft engines suffer from cooling problems?
Any advice welcome...
Peter
Peter
