Hey all, so again got another question to ask. So I got a 1977 Mercury 150 inline 6 and I got water dripping out of the lower number 6 spark plug. Any know why that is and could it be a bad thing?
thanks
There is no cylinder head on that motor.----But there is a water jacket cover with a gasket.----Replace the water jacket gasket.----Or if it is actually blowing out of the sparkplug hole you may have exhaust cover gaskets leaking.
Also while the motor was running I Noticed that water was coming out of the upper exhaust vents. I’m assuming that the exhaust gasket is no good and needs to be replaced. It that a thing for water to come out of that area?
Some water and exhaust gas will come out of the idle relief ports - Normal.
Water leaking around a spark plug from the cylinder block cover won't cause bad running. Gas dribbling out a carb will. Either a float is too high or stuck or the needle valve is bad. Go through the carbs again.
