Hello all, I hope that you can help. I was running my '94 Johnson 120 on the earmuffs yesterday. The engine burped and then the water started spewing out the exhaust. I also noticed seepage where the lower unit meets the shaft housing (along the side), and coming out of the square plate at the base of the shaft housing (right side only), but no water coming out of the tell tale. I have not looked at the lower unit oil to check for signs of water yet, but will do that today when I get home.
What other possible points of failure do you all suspect that I can look at?
Thank you all in advance for your help.
