I have a small (F6) four stroke yamaha outboard. I note that small amounts of water leak out around the rubber gasket between the transom mounted section and the pivoting lower unit. Also, water escapes from the hole where the shifter shaft extends upward to the power unit. Never noticed this before, but frankly, never looked. Is there water in this section above the prop head and below the power head? Can't imagine why there wouldn't be, given that the drive shaft exits the water pump without a major seal of any kind. We;re not talking highly pressured squirting, just leaking. (did a recent impeller replacement, so I;m just kinda spooked.) Thanks for input
