Washing down Powerhead
MIKENVAHBEACH
I have a 2004 bf225 and I run exclusively in salt water. Is it ok to perodically powerwash down the powerhead with water? Are there any areas that should not be sprayed down or is the engine designed to take spray like an automotive engine? After washing I like to spray components with corrosion inhibitor and lubricate moving parts. If this is not wise what is the proper way to get in and clean way built-up salt deposits?
Skinnywater
Re: Washing down Powerhead
The marine techs can add to, or correct me if I'm wrong.<br /><br />As with an automobile engine, washing is a common sense operation.<br /><br />My proceedure would be;<br />I'd keep the washings to a minimum. Instead I'd wash it rarely, yet inspect and apply a moisture barrier very regularly. <br />An initial thourough wash down and a good application of a moisture barrier. <br />My owners manuel says spray silicone. As a note here, silicone is poisonous to O2 sensors. So keep it away from your induction.<br />I'd keep the water away from any electronic components and the induction.<br />I'd also perform my wash before you flush the cooling system. <br />I'd leave the cowl off while your flushing and bring the motor to full operating temperature to utilize engine heat to help dry the water. Compressed air would be even better.<br />After the motor was dry I'd spray the barrier.<br />Touch up any linkages with grease.<br /><br />Diligence with the inspection and moisture barrier will serve you better then regular washings. Even fresh clean water causes corrosion, isn't good for electrical components and promotes rot and fungus.
