Re: Warning module testing
smudge,<br /><br />I'm having the same problem on my 89 mariner 100. I disconnected and thoroughly cleaned all bullet connectors on the warning module and the terminal block (joins the temp sensor, oil level sensor and warning module). So far, its worked. As far as NC/NO, my service manual says if the oil reservoir is full, there should be no continuity....which means it's Normally Open. If continuity exists (full oil tank), then replace sensor. Oh yeah, I wouldn't disconnect the warning module if you decide to pre-mix. I think it still receives a signal from the overheat sensor (single black wire). Good Luck.
