Have a 1995 Mariner 150 while out fishing one day, Warning Module started beep, beep, beep. Replaced Warning Module went fishing for about 3 hours and the Warning Module started beep, beep, beep again.
Replaced Outer Switch Box, Warning Module still beep, beep, beeping. Oil pump ok, Oil cap ok, took readings on Switch Boxes all LOW, Stator checked out ok.
When I check primary input voltage to Coils I get Zero Voltage readings even though the boat is running good in driveway.
Even though I already changed one switch box, do I have to change both as the readings are still low? Or do you believe there is another problem.
Any suggestions will be greatly appreciated.
P.S. When I take green wire from the Warning Module off the Switch Box the beeping stops
