Re: warning horn
LOL!!!! Yeah ogeezer....ya' otta be able to do it.<br /><br />Pull the control from the side mount position and lay it flat. Near the middle of the control you will see a allen head screw. Turn the screw about 2 turns out. With a punch, tap the screw toward the front of the control box. This is to release the handle. Once the handle is lose, remove the allen head screw. Remove the three screws holding the two halves of the control box together and split it open. The removal and installation of the horn module is easy. Reassemble the control box in the reverse order it was taken apart.<br /><br />Don't hesitate to post any other questions you may have. Thanks for posting.
