Unfortunately my dealer told me I had everything in the package after looking at it. No having done it before I didn't notice it only had one plate gasket, one thermostat cork gasket, one plastic valve and the rest of the stuff was there. I decided to go ahead and change both stats using the original gaskets and seals just to see if the problem went bye bye. It didn't even leak but after a few minutes the warning buzzer was back on and the the rear left sensor was again tripped on. Laser temperature readout was about 8 degrees warmer on the side that was tripping. I guess I'm starting to think I might just have a weak water pump more than a clogged water jacket. The pisser is throwing water out but not really sure how much stock to take in that.<br /><br />Going to take a gauge off the other boat and check it. Any pressures I want at an idle you guys think I should be seeing?<br /><br />Is changing the pump a big deal for the home mechanic. I have one here in a box I bought thinking this was the pump at first. Do you drop the bolts off the bottom? Does lower unit just slide down allowing access to the pump? Does it have to have the oil drained? <br /><br />Thanks... Gary
