Warning Horn OMC
I have a 1991 Johnson 70 hp outboard motor. My warning horn does not work anymore. I performed the warning horn test as instructed from manual, by disconnecting tan/blue temperature wire lead from the warning horn lead connector and grounded it to a unpainted surface of engine block, also ignition switch was in the on position. Just a very slight sound everytime I grounded the connection, possibly a faulty horn. The horn is wired under the console.Where can I DSCF0516 - Copy.JPG DSCF0516 - Copy.JPG purchase a replacement horn? Thank you, Danny
Yegboats
Hope this helps
  • warning horn.pdf
