Warning horn/buzzer?
GatorMike
Ensign
Two quick questions. When I turn my keyswitch on my 115 Johnson the overheat buzzer no longer sounds.
Question 1: Is there a quick test I can do to determine if the horn is bad or if I have a wireing problem?
Question 2: I have searched Iboats parts & accessories along with a couple of other online parts sources and can not seem to find a price on one. Does anybody know where I can find one online?
Tyme2fish
Re: Warning horn/buzzer?
Same problem here. I hope you (we) get a response.
jonesg
You'll get more response if you post the year and model number.
Dissconnect the (tan wire) heat sensor and ground the power pack side of the wire to the block, ignition on, it should sound the beeeeeeeper.
If not I would try putting 12v to the beeper and see if it works.
Read this post.
http://forums.iboats.com/showthread.php?t=85657&highlight=test+warning+beeper
The search function shows other posts on beepers.
