Re: warning beeper
I was experiencing the same thing this weekend.<br />I have a brand new VRO pump, full oil tank, blub is hard as a rock, plugs show signs of pleanty of oil, oils resivoir level indicates pleanty of oil is being used each time I go out.<br />Once in a while, the horn starts beeping at about 1300 rpm. If I drop to an idle, or rev it to 1600 rpm, it stops. For some reason, it is thinking that the oil flow at around 1300 rpm is not enough. If I pump the bulb, the alarm stays on and the engine starts smoking, and almost dies from too much oil.<br /><br />Should I just ignore it? Are the electronics too sensitive in the VRO? Should I buy another $250 VRO? Should I just dump this piece-O-dung Johnson and buy a real motor?
