jwstandiford
- Sep 5, 2004
- 14
I have an Evinrude 25hp, 1978 Model # 25852 tiller opperated outboard. I want to add an electric starter to this motor and have done some research into what parts are needed. I have also come across a kit with starter, bracket, and flywheel for a newer 25hp motor and would like to no if I can use them to add the starter to my motor. Here is the info. that I have.<br /><br />Model#25852 Parts needed- <br /> Mounting bracket- #0333929<br /> Starter- #0386591 (11 tooth)<br /> Flywheel- #0582011 (on my motor)<br /><br />Parts in Kit (speced as 1988-92)<br /> Mounting Bracket- #0333929<br /> Starter- #583473 (9 tooth)<br /> Flywheel- #583474<br /><br />I am wondering if I can replace the flywheel on my motor that requires the 11 tooth starter with the flywheel in the kit? I was thinking that the starter and flywheel may just be an updated version since the mounting bracket is the same. <br /><br />I also have one other question. I was having a problem with the motor running hot. I replaced the impeller and t-stat and flushed out the system with air and water both at about 100psi to be sure that it was clean. I was getting good flow at slower speeds but at WOT it would still get hot fairly fast. I moved the motor down a couple of notches and it seemed to improve the flow at WOT and not heat up as much. Is it possible that I had it trimmed to high and the motor was sucking air and water at WOT because of the aerated water at the back of the boat? This is my first outboard and I have just been going by the info that I have read from this forum (which has been very helpful). Any info is greatly appreciated.<br />Thanks
