Re: Want to install lighted dash switches 1989 Sea Ray 200DA
NYBo is correct...(to expand) Switch wiring and add a negative lead to actually illuminate the switch. The terminal should be labeled "-". If not, it's (usually) the terminal that is located away from the standard terminal cluster.
