wall carpet replacement
oldbouy
I had a leak in both side windows , water drained into the wall carpet , I sealed the leak , the water damage caused black mold in a small area . I have been washing with vinegar and water , letting it dry and rewashing again 2 times . should this wall carpet be cut out and be removed ? it is in a 2 foot long by a 1 foot wide area for both sides . where to purchase replacement wall carpet ?
Chris1956
Most boats use a marine carpet for places like that. Marine carpet fibers are some form of plastic, which doesn't stain easily and is pretty tough. They will normally hold up to gasoline and oil without damage.
I would try some hydrogen peroxide and see if it kills the mold. Use it on some obscure portion of the carpet until you see that it works and doesn't affect the carpet.
If that doesn't kill the mold, try some dilute bleach in the same manner.
Chris1956
I have used cleaning vinegar in the Windex dispensers. It was not as strong as the ammonia that is generally used, IMO.
I think the mold will laugh at the vinegar. I am happy to be wrong.
oldbouy
I am talking about wall liner , a leak came from a crack in a window , drained down to the next ledge and started growing horizontally to about 2 feet long . the stain looks black , could that be just a stain from the water leaking or would this be Black Mold ? this is my 1st time dealing with this type of cleaning problem .
Lpgc
Get a carpet cleaner and pull the cleaning liquid out with that.
My cuddy cabin had patches of black mold, I went over it a couple of times with a carpet spotwasher using diluted bleach and then again a couple of times with carpet cleaner, turned out great, no sign of any mold since.
oldbouy
thank you for your reply , I will try this method . sounds easier that cutting and replacing
Lpgc
I should've used breathing apparatus spraying bleech around in the enclosed space though!
