Walkthrough window - bolt
RChaparral
All - 2009 310 SS…. Trying to locate the bolt(?) which is installed about half way down on the walkthrough window that is used to gain access to the bow. It is used to prevent the window from sliding up and down on the “hinge” when it is opened or closed. no idea what it looked like or any specs. Thank you in advance. J
Yegboats
Sounds like a Taylor made part... You can call around to see if any boat dealership may have it, honestly it's unlikely they'll be able to help though they may be able to order or you can.
1170920
part #1170920
part #1170920
Hinge retainer clip (requires: 9090320 screw)
RChaparral
1170920
part #1170920
part #1170920
Excellent - thank you. I have litterally spent hours searching for this. J
Yegboats
You may have luck with a Lund dealer having these. The Lund part number is 1789116
