Re: Wakeboard tower installed/ gel coat cracking. help
I know that tower! DIY Wake Pro Swoop! I just installed the exact same one on my boat. Look familiar??
http://forums.iboats.com/attachment.php?attachmentid=52145&d=1273157260
I found those 2 aluminum brackets to be wayyyyy too small to distribute forces on the backside for me to feel good about it. One of the places DIY really cheaped out IMO. So here's a pic of how I inexpensively backed mine up to distribute forces long and high to hopefully prevent this problem:
http://forums.iboats.com/attachment.php?attachmentid=52148&d=1273157330
I need to tell you that weather has not been cooperating, and I have not ridden with this tower yet. So I can't 100% vouch for whether my setup will work or not. Should know more in a few weeks.
I will however agree on the comment about the curved surface that you mounted those rubber pads to. The mounting location is far too curved. I can see air between the rubber and the boat in your photo. And I am quite certain that's contributing to your problem more than anything else. These rubber pads need to be mounted on a very flat surface, or else you need to find some sort of curved replacement for the flat rubber pads. My surface is nearly completely flat, especially compared to yours, so I don't expect this problem. A piece of machine aluminum that follows the contour of your sharp curve at that location could be made, and it could be made oversized to cover your new cracks. I'd expect any machine shop should be able to make feet like this. They'd need your boat to mold the curve. I also like the hard plastic idea...but I too have no idea what the heck a "plastic shop" is or where I'd find one. And I think you'd still want a gasket of some type between the aluminum (or plastic) and the gelcoat, but it wouldn't need to be as thick as the one DIY provided.
Frankly I don't see much other option for you. And I do belive the cracks will continue to spread and get worse if you don't take action before using it again. I think your boat is not really a good candidate for these types of mounting feet, since it appears to have few flat surfaces for you to mount the feet to.
Anothing thing I did was partially counter-sunk the drilled holes on the outside of the gelcoat using a rounded dremel tool grinding stone...sort of like this one:
http://www.dremel.com/en-us/Pop-ups/Pages/ProductImages.aspx?pid=517&tab=1
I recall reading instructions from another tower manufacturer that recommended doing this to help prevent the thru-bolts from contacting the brittle edge of the gelcoat and possibly starting a crack.
BUT...I really really think your #1 problem is the sharp curve where your mounting feet are installed...compounded by the small backing plates.
