w55 motorguide
4x4350
i have a w55 motorguide tolling motor it turns fine but don't run what could be wrong
Barnacle_Bill
Re: w55 motorguide
Would you like to explain that a little better. Are you saying the motor turns but the prop doesn't?
John_S
Re: w55 motorguide
Unplug it from power. This will reset the electronics. With power off, turn prop with finger. Should spin freely with a small thumping resistance from the motor poles. Remove prop and check for fish line.
Repower and check if you can turn speed on/off. Does it beep on on/off? Does it beep on increase/decrease speed?
Do you have another controller to try? If not, there are two wire nuts inside the directional head. Take them apart (w/power off) and momentatirly apply 12V to the wires going to motor. If motor spins, digital controller board in motor is probably bad or some connection on it.
Hillclimber
Re: w55 motorguide
Are you saying that the steering (directional) motor runs, and you can turn, but not the drive motor?
