2001 F115 VST EFI pump is on the bench. I would like to know if this should "run" and make any sound if I hook it to a 12V car battery?
And if not, are there any comments on aftermarket pumps that cost around $35 verse the OEM costing around $275?
Prior to pulling the pump:
- 12v source to pump connector tested good
- vst pump filter 85-90% blocked with varnish
- not much crud in vst reservior
- Injectors cleaned
- LP pump replaced
- ball pump tested
- inline reservoir is filling
- rail pressure zero...
- Injectors cleaned
- LP pump replaced
- ball pump tested
