VRO2 or OMS?
fixmyevinrude
How do I know if I have a VRO2 system or an OMS system? Motor is a 1994 Evinrude 200. The Model # is LE200SLERS.
ezeke
Re: VRO2 or OMS?
Look at the top outlet nipple - the later VRO's are brown. The OMS pumps top outlets are not brown.
There is also a noticable difference in the metering of the oil with the VRO2 which uses a much wider range than the OMS.
fixmyevinrude
Re: VRO2 or OMS?
I believe the hose that goes from the oil tank to the motor is black but I would have to check. I am talking about the the hose with the primer bulb in it.
fixmyevinrude
Re: VRO2 or OMS?
My mistake . You are talking about the outlet nipple on the pump on the engine. I will have to look. Thankyou
fixmyevinrude
Re: VRO2 or OMS?
The outlet nipple on top of the pump is black and appears to be replaceable as there are 4 small screws that hold it in place. There are also 4 wires that attach to the pump (purple, beige, white and black). I would assume that I have an OMS pump from the comments above ????
fixmyevinrude
Re: VRO2 or OMS?
Perhaps mine has faded. I would say it is black or maybe a dark shade of gray. The pulse line nipple on the engine side is blue. Looks like it maybe is made of aluminum and anodized bright blue.
ezeke
Re: VRO2 or OMS?
It's OMS if it has a repairable outlet.
Most of the VRO and VRO2 pulse limiters were replaced with the blue and gold subject to a service bulletin. That is not a good indicator of the pump version.
seahorse5
Re: VRO2 or OMS?
If the original pump was replaced with a 1998 or later version, that outlet nipple is held down with an oval shaped metal plate and 2 small Torx screws. If that describes your pump, then the nipple is replaceable from your dealer.
