vro wiring
I have a 1998 Evinrude 115hp motor. I am trying to put a vro on it. My question is that I have 2 wires on the tank and do not know where to connect on the engine. Please Help! Yes, i'm a rookie on this.
Howard
rickdb1boat
Re: vro wiring
One will go to ground and the other will go to the warning circuit wire, which is the Tan temp sensor circuit wire..
Re: vro wiring
Thank you for getting back with me. Is the tan wire connected to the red wiring harness? I hope.
Howard
Chris1956
Re: vro wiring
Howard, It sounds like you need a service manual. You might look on maxrules.com for a wiring diaghram.
Generally sensor wires ground when there is trouble, completing the circuit and sounding the horn. Connecting a red wire (usually +12VDC) to them is usually not correct.
