I have been having trouble with my wot on a 1985 Johnson 150 thinking it might be something with the VRO...<br /><br />I installed a pulse limiter as recommended by some of the articles mentioned on this forum. Does the blue face go towards the VRO? <br /><br />The pulse limiter I installed had a nipple on each side. When I installed it, my new hose section got a little squished, not a lot. Is that going to be a big deal?<br /><br />I hooked up a clear vinyl hose to the output of the VRO with a pressure gauge to monitor the performance of the pump. The OMC service manual stated that I would see the oil injected into the gas. I could not identify any signs of oil going into the gas. Would I be able to see that at the 150:1 when idling? <br /><br />The pressure was about 4 psi then gradually dropped to about 2 psi when the pump clicked (oil injected?) then dropped to zero. This was at idle speed of around 1800 rpm on muffs. Then back up to 4 psi. Even though this was at idle speed does it sound correct?<br /><br />While playing with the VRO my idle speed dropped to 1000 rpm. I lost spark on one side of the V-6. I tapped on the power pack and vroom, all were firing again. Another tap and lost them. I have a new power pack on order. I hope this is my problem with the wot bogging.<br /><br />Any help with the above questions would be greatly appreciated.
