Hi Phill
Go to the FAQ httpwwwiboatscombbboardbbBoardcgiaviewforumfid36 http://www.iboats.com/bbboard/bbBoard.cgi?a=viewforum;fid=36
and read about VRO.
Basically, it can't burn up single cylinder. A carb can do that, or the wrong sparkplug, but a VRO mixes fuel and oil and delivers the same mix to all carbs. You don't say what motor it is on, or if in the process of using the motor you used some of the oil in the reservoir, but as a rule, when I do a rebuild or change out VRO components I run a 50:1 mix in my fuel until I know the VRO is functioning again.
good luck,
fp
and read about VRO.
good luck,
fp
