BigBassin78
- Aug 13, 2011
- 64
Would I be wrong in assuming that a later year model VRO tank and sensor such as a 96 will work with my 95 J150GLEOM harness? The tank and sensor look identical. The only difference I can observe is the actual harness connection, they moved to modular harnesses in 96. But the the 2 lead wires for the sensor are the same colors. If I splice the old connectors it should work right?
