Re: VRO disconnect '93 Evinrude 40hp
Look at the back of that pump and you will see a harness that runs to a black rubber plug.That plug will have 4 wires in it. Purple,gray, tan and black.Unplug that plug ,tape off the non pump side cause you,ve got voltage there,mix your fuel, remove the engine fuel connector and pump fuel into a clean resepticle until you get mix,and you should be off.
