Scaaty
- May 31, 2004
- 5,180
Rusted through stat housing on an (original housing only-repower 96) 77 350 Volvo Penta 280. Found a similar one on ebay (P/N 835905), and need to know if it will fit. I have some fudge room on the raw water hose, and circ pump hose, Two hoses to exhaust mans can be made new and room to route. This a can do situation? I cant tell if the 835905 has the stat in housing, like the old one does. See the pix. (I was putting a new circ pump on, and while I had the housing off, glad I took a small hammer and tapped on it and found a dull thud spot on the bottom. Awl went in pretty easy). Also if this won't work, anyone know where I can find a new housing? Thanks for the info in advance<br />Heres the original setup..<br />
<br />Heres the old housing..<br />
<br />And what I can get if it will fit..<br />
