All,
I need some smart help. My wife said to research a new boat motor swapping from ford to chevy based block. I know everything would have to change on the engine itself.
I have a 1996 Osprey Fisherman 22' glass cuddy. The boat came with a VP 5.0 FL PHUR motor. As ford quit making marine engines manifolds and risers are quite spendy, as are other parts compared to the gm block market. I have a 290 DP-C1 out drive with 1.95 gearing. I know I will have to reprop. Manifolds and risers are center rise, believe the risers are same as some of the gm motors use.
Would I have to regear or replace my Outdrive if I wanted to put in, say, a 5.7 gi or gxi in replacement? I know I would have to reprop. Would the exhaust pipe work with a gm motor or would that have to be replaced as well? I know motor mounts would move. What about coupler etc? Thanks for the help!
Dan
Dan
