VP DP-C Bellows clamp or glue
Pboat44
Replacing bellows (876294) on ‘93 VP 572A w/DP-C drive. Does the Flywheel cover need removed to attached front hose clamp? Or is bellow glued? Engine pull necessary?
no, you either remove the whole outdrive, or just the transmission (shortcut in the stickies). if you remove the trans, you will need a new o-ring.
you use the clamps, that is it, and with any AQ series drives, you must orient the clamps properly or they collide with the other bellows
