mia248vista
- Jun 9, 2008
- 44
2003 Volvo Penta GXi-B
DP-S
Recently I had my engine go into engine protection mode on two different occasions.
This happened one time about 2 months (5 uses) ago but the problem went away after putting the shifter in neutral.
However this weekend the problem would not go away until I shut off the engine. I dropped the anchor and did a very brief inspection to see if there was something obvious that was wrong. Could not see anything. When I started the engine to head back everything seemed ok until i got up on plane and hit some chop and the engine went back into EPM. In fact the times that I have had the problem it has been when the boat has bounced in the chop. When I got home I put on a code reader but the ECM had no stored codes (all 12s).
I should also point out that the gauges report 140F for temperature and 60psi on the oil pressure.
Any ideas of what I should do next.
DP-S
