Vortec is Awake
FreeBeeTony
I brought the Vortec to life today.<br /><br />After some smoke....it smoothed-out nicely.<br /><br />When I started it in the fall I noticed a strange noise coming from the rear of the engine.<br />The outdrive wasn't installed at the time.<br />Heard the same noise today......almose seemed to be external to the engine. <br /><br />Is it possible the coupler is making this noise?<br /><br />It's not present all the time.
Don S
Re: Vortec is Awake
Only if you left the bolts loose. Without the drive, nothing contacts the coupler...... Unless you got your shift cable up againt it.<br />If it's a clicking sound, did you check the exhaust shutters while you had it all apart?
FreeBeeTony
Re: Vortec is Awake
Hi Don....<br /><br />Yes, checked the exhaust shutters. When I say I checked them I mean I verified they were there. Is it possible they are making this noise?<br /><br />Bolts are defintly tight.<br /><br />Shift cable? How can that contact the coupler? Can I check for that with the engine installed?
Don S
Re: Vortec is Awake
It could be routed wrong and just pushed up against the coupler. Just run your hand down the cable and see if it contacts the coupler along the way. (Engine off of course)
FreeBeeTony
Re: Vortec is Awake
From under the engine?<br />Can't get to it from underneath<br /><br />How about from up top?<br /><br />Will check it tomorrow.<br /><br />Just covered it up.<br /><br />Seems to shift ok.......
Don S
Re: Vortec is Awake
Yea, from the top. Start at the top of the cable, should go down to the transom shield just above the exhaust Y.<br />It will shift ok, until the coupler rubs through the cable, IF that's the problem.
FreeBeeTony
Re: Vortec is Awake
Is it possible it's the exhaust shutters?<br /><br />I'm wondering if it's the shutters "flapping" back and forth..........<br /><br />Will check the cable tomorrow.......<br /><br />Thanks for the tip Don.
Don S
Re: Vortec is Awake
Anything is possible, but without hearing it, it's really hard to say. Do you have a mechanics stethascope (sp) you could listen to where the noise is comming from,<br />When you had it apart, what did they look like. The old style (stainless with rubber edges) would make noise if the rubber was burned off. The new style won't make noise.
FreeBeeTony
Re: Vortec is Awake
Can't really remember what they looked like....<br /><br />And I don't have a stethascope....
lilmandavis
Re: Vortec is Awake
i know that my coupler makes a little ticky noise but thats when the drive is on and under a load.
ziggy
Re: Vortec is Awake
fbt, i use a hearin hose. probably not as good as a stethiscope donS is talkin about, but it does amplifie the sound...any ol hose will do. can be very instumental in findin a noise, even thou low tech..... :) hows the rpms?
FreeBeeTony
Re: Vortec is Awake
No problem ziggy...........just glad you guys remember who I am......... :) <br /><br />Haven't ran it under load yet........should be in the water next w/e.<br /><br />Will post after I give it a test run!!<br /><br />What type of hose are you talking about? Rubber ok?
Don S
Re: Vortec is Awake
Come on Tony, you're reading way too much into this stethescope and hose thing. The Steth-a-whatever..... costs about 10 bucks at NAPA. Any hose or even a long screwdriver or broomstick will do the same thing. Just hold one end to your ear and the other to where the noise is coming from. The place where the noise is the loudest is the likely cause of the problem.
John_S
Re: Vortec is Awake
Tony, glad to see you got it fired up. I can't help you much with the noise, only to say I didn't have any while running my engine yesterday. Hopefully, it is just the shutters. Should be easy to id with the stethoscope. Good Luck.
Re: Vortec is Awake
Ayuh,........ Same Here.........<br /><br />But,........<br />I wanta hear that it's Screaming at 5000rpms WOT...........................In the Water of Course....... :D :D
Don S
Re: Vortec is Awake
I hear ya Bondo...... If it doesn't go over 3500 rpm, I'm way too close to Tony to be safe. :p :D :p :D
Re: Vortec is Awake
Originally posted by Don S:<br /> I hear ya Bondo...... If it doesn't go over 3500 rpm, I'm way too close to Tony to be safe. :p :D :p :D
If it Don't make more than 3500rpms,............<br /><br />I Don't Think AnyWhere on this Planet will be Far Enough Away................... :D :D
FreeBeeTony
Re: Vortec is Awake
Checked the shift cable today.....seems to be clear of the coupler.<br /><br />I'm betting the noise is the shutters.... :) <br /><br />Will be in the water next w/e.<br /><br />Should I really be looking for 5000RPM's?<br /><br />I planned on moving up to a 17" prop.<br /><br />Will be happy to see 4400.....<br /><br />Isn't this SBC rated for 4400-4800?<br /><br />And yes.........if it doesn't go above 3500.....I will put a hole in the hull!
Re: Vortec is Awake
Ayuh.............<br /><br />I'm Hope'n,+ Pray'n that you'll be SCREEMING at 5000 with All that Extra HorsePower.................. :D ;) <br /><br /><br />Being a SBC,.... There's really No Worries about Twisting it to 5500rpms.......<br />But,..... The Power will run out around the 4800 point, due to the Cam............
