Tail_Gunner
- Jan 13, 2006
- 6,237
http://www.volvopenta.com/volvopenta...V6-240-CE.aspx
Direct fuel injection.
The move from multi-port technology to direct injection means atomized gas enters the combustion chamber at 2250 psi. Compression ratios of up to 11.5:1 create a cleaner burn and fewer emissions. So more energy comes from each drop of fuel.
- See more at: http://www.volvopenta.com/volvopent...ive/Pages/V6-240-CE.aspx#sthash.GgNS5Qwx.dpuf
Variable valve timing
We refused to accept the compromise of a fixed camshaft. Variable valve timing now allows each movement of the intake and exhaust valve to be optimized for speed and load. You?ll have higher torque and acceleration across the full range of RPM?s.
