1978 volvo penta aq130d/280
Took it out for the first time. Starts right up and idles fine. Goes into reverse fine. Give it throttle to the first position and still fine. I ran at this speed for several minutes to get engine temp up. If I increase throttle it falls on it's face and will die if I do not return throttle to first position/idle. Sometimes it will run at WOT position without dying, but does not have even 50% power and surges. If I put to half throttle or so it will start to sputter and die, but if I quicky pull back trottle a small amount it will gain some power. Using this technique I was almost able to get it on plane.
Over the course of about an hour in seemed to get better until it just quit and would not restart for several minutes, acting as if it was flooded.
Any ideas on what else I should check?
THanks!
THanks!
