I have a 1986 invader with a aq125b and 270 outdrive. My tilt motor has stopped working. I checked all the wiring and connectors and it all looks good. So i disconnected and removed the motor from the assembly and checked the voltage from the black and brown wires with a multi meter and i got 11.8 volts. I jumped the motor directly to the battery and it worked. Also when i toggled the switch in either direction i can hear the relays clicking. Thanks for any help on what to check or do next.
