rwidman
- May 27, 2004
- 1,396
Since I bought a new boat, my 2003 Glastron with 5.0 engine and SX drive has been sitting waiting for a buyer. Since January. A couple times, I have started it on muffs and warmed it up to operating temperature. Never messed with the shift or trim. Yesterday, I started it up, then tried to shift into forward and reverse. No go. I was able to fix that by lubricating the cable. But:
I tried to raise the drive and it won't move. No motor noise and if I keep the switch engaged, the 50 amp breaker on the engine trips. I can see on the volt meter that it's drawing current because the voltage drops. I had to leave it to do something else, besides, it was near 100 degrees outside.
I'm thinking the pump motor is stuck or jammed and not turning. Any hints or suggestions?
