Re: Volvo SX: Rust on shift mechanism
That's a slightly different (and better) picture than what I see in my 'NC' V/P manual. Mine does not show or mention the steel ring, only that the larger gap/space should be on the outside. <br /><br />I did a closer inspection and using your picture as a guide, I looked (from the outside) for the steel ring. Gently probing that area shows no steel portions. I can, with a little imagination, detect the springs, but not the ring.<br /><br />I'm starting to think that the final step in your picture about coating the outside surface with gasket sealing compound was not done. This step was not mentioned in my manual. This step would obviously help protect that spring that is exposed to the world.<br /><br />What version of the manual are you referencing? Mine has a 1996/4 printing date.<br /><br />I still need to double check for the presence of water in the gear lube, I'm a bit hampered in that my stand is so low that I can't get a catch pan under it. (The boat sits very low on the trailer)<br /><br />Thanks,<br /><br /> johnbo
