Volvo SX Drive Wont go up or down
Larryfitz18
Hi All, Im new here and am having a problem with my trim. Currently it is stuck in the down position. I have checked and I am getting power to the relays so I assume that power is going to the motor. Ive checked the fuse and thats fine as well. Does this mean my trim motor is shot? Thanks for any help you can give.
bruceb58
Re: Volvo SX Drive Wont go up or down
Bypass the relays and try to operate the pump with jumper wires from your battery.
Don S
Do the relays click when you hit the button?
Don S
What is the full model number of your engine (not drive)? Or the serial number?
You may have a small fuse on the pump near the relays, did you check it? Also check the connection of the trim pump harness to the trim pump.
Larryfitz18
The model number of the engine is 4.3 GL. I did check the fuse on the side of the relays and that was fine. I will double check the connection of the pump harnes to the pump. Thanks
Don S
No, that's only part of the model number. There is a letter or letters after the GL, that's the important ones. Below is a list of the different 4.3GL's.
How did you verify you have power to the relays?
Larryfitz18
Sorry about that the model Number is 4.3GL PWTR. I verified power to the relay with a light tester. I really appreciate your help and sorry for the delay in getting back to you.
Larryfitz18
I will double check power to the relays. What would be the problem if I wasnt getting power to them?
Don S
To test the motor only, in the drawing below hook jumpers to connector C and go directly to the battery + and - terminals. It's a reversing motor, just reverse the wires to run the other way.
If the motor runs follow the following steps to troubleshoot the system.
Here are some abbreviations I will use. BV= Battery Voltage, R=Red, B=Black
You may want to print out the picture below, makes it easier to follow.
1. Hook up your meter for 12V DC B on the negative terminal of the battery, with the R lead, check relay sockets 30 on both the up and down relay. Should show BV. Next with the R lead touching a 30 terminal on the relay (doesn’t matter which one), with the B lead touch each of the 86 and 87a terminals in both relay. Should show BV on all terminals.
If this all passes, you have good power and ground from the battery.
2. Hook the B lead to any one of the 86 or 87a terminals. With the R terminal of the meter touching 85 of the up relay, have a helper push the trim up switch. You should see BV .
Repeat process on the other. Repeat with the down relay and the helper pushing down on the buttons.
If you show power on both, then the trim circuit is working.
3. Next you will need two jumper wires with male spade terminals on each end.
On up relay jump between 30 and 87, on the down relay jump between 87 and 87a. The pump should trim the drive up.
Next, On the up relay jump between the 87 and 87a terminals and on the down relay jump between the 30 and 87 terminals. Drive should trim down.
If all of the above checks out, you have a faulty relay or two.
attachment.php
Larryfitz18
Thanks so much I am going to give it a try on saturday and I will let you know how things turn out.
PJFWH170
Good evening everyone,
I'm having the exact same problem with my drive. My question is; Will this troubleshooting procedure / schematic work on a 3.0GS PEFS engine ?
bruceb58
It should be very similar if not exact.
For future reference, you should normally start a new thread.
