I am working on a boat I bought a few weeks ago. It is a 2001 Larson with a 3.0 Volvo and SX-M drive. I just spent quite a bit of time aligning the engine and replacing the ring gear on the flywheel, impeller, plugs, etc..
Now I turned to the drive to drain the oil and check it out, and I had some (3) metal particles on the magnet. Two of the particles are about 1.5mm flakes that are thin, and the third was a piece that was a bit thicker but also about 1.5mm (irregular) in size. I ran a magnet around in the oil after it was drained and I couldn't find any more particles. The oil was fairly black, but it didn't have any water in it. I did the complete pressure and vacuum test on the drive, and it passed with no problem (it held 15in of vacuum for 1/2 hour before I disconnected it). I don't know how often the gear oil was changed, or what oil was used. It has a strong "gear oil" smell so it might be some kind of synthetic oil.
So, the question is, what should I do about this? I am planning on using the Volvo synthetic oil. Should I fill it and run it for a while then check again, or should I be concerned enough to take this somewhere to get it checked out? I have the volvo manual for the drive, but it looks too complicated to work on myself (too many special tools). Is there something a shop (or I) can do to evaluate this thing without taking it all apart?
I did run the boat on the water before I bought it, and it performed as it should (quiet, proper top end speed, etc.) Now I know I should have checked the gear oil plug magnet rather than just looking at the dipstick.
Also, I'm thinking that the previous owner overfilled the gear lube, because it doesn't look like the middle plug was ever removed, and there was gear lube in the bellows (no water). I'm not too concerned about a seal because the pressure and vacuum test were fine, and I read on here that overfiling can cause oil in the bellows (is this correct?).
Thanks
Fred
Thanks
Fred
