Volvo questions
jastacey
When I was doing the shift cable replacement, I noticed that the hoses that run from the t-stat to the exhaust manifolds looked old and they seemed kinda brittle, my question is, can I use auto heater hose? or is there a marine equivalant?, also I took the drain plugs off on the exhaust manifolds and found black gooylike sand like stuff, is this normal? I used some copper wire to probe/loosin up the crud, I think I got most of it out, could only get about 2" of the wire into the drain hole, my next question is, should I take the risers off the manifolds and check those water passageways? and I remember from another post, that there should be good metal between the rectangle holes and the main square hole in the manifolds,or am I opening a can of worms? I don't know the history on this boat engine, but in most aspects it looks like it was taken care of, one last question, when I had it out on the water this weekend, I noticed that the battery voltage was kinda low ( 12.5 - 13 volts )and the fish finder has an alarm for low voltage, and it was saying the same voltage read out, I checked the connections at the battery and on the alt. and the connections at the starter and they look to be tight & clean ( no corosion ), I'm thinking that the regulator my be bad, ( the alt. is a Paris-Rohlm 14V - 50 Amp unit ) looks like it is OEM, should I just replace it or is there a simple issue that is being over looked, the engine is a AQ225D - SN CU40153 - 1983 year
Don S
Re: Volvo questions
Heater hose of the proper size will work fine. Just make sure there are no kinks in the hose, just a nice smooth curve from the housing to the manifold.<br />Just take your alternator to a Starter/Alternator repair house, they should be able to fix it for a lot less than a new one.<br />Regarding your manifolds. Most of the "Stuff" plugging up the manifolds is rust FROM the manifolds. They don't last forever, and if you do keep cleaning them out, you may end up with a hole in one where it rusted through and you will get water in your engine. I usually look at clogged manifolds as an indication to replace them.<br />It's cheaper to replace manifolds and risers than to replace them AND the engine.
jastacey
Re: Volvo questions
Thanks for the info Don, One more question, should I use a Volvo manifold set up, or could I go with a aftermarket product, is there a differance performance wise?
Reel Poor
Re: Volvo questions
Google...GLM Exhaust Manifolds and have a look. Three year warranty on these.
