volvo penta, vibrating, grinding on turns
angelo47
I have a 1985 volvo penta 280, experienced some vibration this season also on a turn sound changes to almost a grind, hard to discribe, is there a gimble bearing in that unit or could it be a universal joint, any help appreciated.
Dunaruna
Re: volvo penta, vibrating, grinding on turns
Technically, it's not called a gimbal bearing on VP's, it's a support bearing. But yes, there is a bearing and there is 2 uni joints.
You have wornout uni-joints.
Don S
And probably all caused by water in the bellows. If there is (or was) water in the bellows there are also some other things to check for.
angelo47
Thanks for help
