Erik-The-Red
- May 2, 2007
- 21
2001 Glastron 175 SX, 3.0L Volvo (GM), SX drive
Parked the boat last October and everything was working just fine. Got the boat out this weekend to clean up and get ready for the season, charged battery to full (13.5 v), added fresh gas and the engine fired right up. Tried to trim down and it won't budge. Up works, but now its trimmed up as far as it will go and it won't trim down. When I press the switch I can hear a "click" from the relay, but the pump motor won't run when trying to trim down. Works like normal on trim up. Fluid reservoir is about 1/2 full, but I don't see any marks on the reservoir to indicate where "full" should be. I'm assuming the trim pump is ok since it runs fine on trim up. I also assume the relay is working because I can hear it click when I press the trim down switch on the control. And I can assume the switch is working ok since trim up works and I hear the click at the relay on trim down. Should I not assume these things? What should I do? What should I be looking at to fix this issue?
Thanks for any help or advice!
