Volvo Penta Trim / Tilt
Status
Not open for further replies.
josulli
I have a 1993 24' Chaparral with a 5.7l engine and a Volvo Penta Duo-prop outdrive (DP-C or DP-C1 not sure?). I have been having trouble with the tilt/trim. The down was working fine but the unit would not go up. I have replaced all 4 relays, the potentiometer, and I have cleaned all the electrical contacts I could find. The unit now goes up and down fine, but it automatically stops about 2 inches from the black rubber bumper.<br />Any ideas?
bigbrownbuku
Master Chief Petty Officer
Re: Volvo Penta Trim / Tilt
could be thats where the trim limit is adjusted too.<br />the switch is mounted to the top of the steering pitman arm held down by a small bracket. thats where id start.
zebrathree
I have a 1995 DP-C1 also. I just removed a trim cylinder and had it rebuilt due to a leak at the rod. The trim cuts off about 3 inches from the full down and have to use the tilt/trim switch to trim any further. Can you tell me where the limit switch is eaxactly and how to adjust. mentioned previously the switch is located on the steering pitman arm. Is that inside the engine compartment? Also, does the plastic gear and spline on the top of the outdrive have anything to do with it?? Thanks for your time! John
Status
